BNIB TC Sounds / Audiomobile EVO-R 12" D4
  • 7
ciaonzo
TheContinental
11,703
76
WI
D4 Audiomobile EVO-R 2312 (TC-9)
Flawless, never used. Very rare driver. Relatively efficient and my ear tells me this has a shorting ring. Loud, low and clean.
Thiele / Small Parameters
Frequency Response (+ 2 dB) 20 – 600 Hz.
Sensitivity SPL (2.83V/1m) 89 dB
Impedance (Nominal) 8 / 2 Ohm
Re VC (ohms) parallel / series 1.5 / 6.2
Continuous Power (RMS) 750 Watts
RMS amplifier ("Musicpower") 1,500 Watts
Minimum Power (RMS) 200 Watts
Resonant Frequency (Fs) 24 Hz.
Qms 3.2
Qes .39
Qts .35
Vas (Cu. ft./L) 2.0’ / 59 L
Maximum Excursion (Peak-to-Peak) 60 mm
'X-MAX' (Linear one-way ) 27 mm/ 1.06”
BL (Tesla / M) 22.1 TM
Sd / per LMS (Sq. In./ Sq. M) 77 / .050
Mmd 195 g
Voice Coil Diameter 3.0”
Driver Weight 32 lbs.
The EVO-R or "Type R" series of high-performance subwoofers were specifically developed to deliver stellar sound-quality ('SQ') plus true, "World-Class," High-Definition SPL ( HD SPL ) in the smallest enclosure possible, and do it at unprecedented price points.
Ideal for "forced-beta" small, sealed applications, the EVO-R is equally adept in VENTED, and or SPL "competition" type of ported box (often tuned above the recommended 30 Hz. for optimal Sound Quality) systems. In either application, the EVO-R will outperform virtually all other high-performance subs (due in part to their extremely powerful motors and lower Qts), costing upwards of twice as much.
In addition, at less then 7-inches of mounting depth (for the EVO-R 2312), the EVO-R drivers will often "fit" in applications, where other, more expensive, long-excursion subwoofers, simply will not work (as you need to add an additional inch of rear clearance behind the back-plate, to accommodate for the vent exhaust).
This means that for many applications, the EVO-R (and the MASS series as well) are often the only solution where one sub must move the air of "two," and do it in a an installation with limited depth.
Though the EVO-R has a similar linear-excursion envelope ("X-MAX") as the highly-regarded MASS series, it also has a slightly lower 'Q' and a much longer "overhung" VC motor, featuring 25% larger magnet structure. As a result of this more powerful motor, even SMALLER types of enclosures are possible, OR more potential SPL OUTPUT, with greater usable excursion.
In addition, to take advantage of the proliferation of the new generation of high- output, mono "Class D" amplifiers (and their inherent low-impedance capability), the EVO-R series subwoofers were designed to handle long-term power of well over 1,200 watts, into 2 ohm loads (or less) and still maintain excellent sound quality.
Much like it's brothers in arms, the MASS and EVO series, the EVO-R subwoofers include many recognized performance features, including cast-alloy frame, "STACT" magnet motors, with precision, CNC machined, extended magnetic-gap motor parts, spun alloy cones, large rubber surrounds, large -diameter, progressive spyders (with in-line leads) and extraordinary excursion, for high-output with exceptionally low-distortion. This is what "TRUE" hi-performance subwoofers are all about.
$250 shipped, CONUS.
CONUS only, please.
Johnny!! //content.invisioncic.com/y282845/emoticons/wave.gif.002382ce7d7c19757ab945cc69819de1.gif
the marketing blurb for this sub is funny. Probably somewhat true though, i've always liked the way the eclipse TC-9 subs sound and this is probably a tad bit nicer.
Oh, definitely. Excursion is quieter, slugs are thicker, and I'm positive this has a shorting ring. Also have to remember the market itself when this thing came out, somewhere around 2000. It was the best, side-by-side with the MASS. Funny now, but unbeatable at the time.
2000?¿ Hot ****, you're old. //content.invisioncic.com/y282845/emoticons/scared.gif.f134e57c6c93ccd0f15aa5ac32c7d4a0.gif Seems like a pretty solid driver!!
ciaonzo
TheContinental
ciaonzo
WI
ciaonzo
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
