Sold BNIB-Stetsom 2k6d-$625 shipped in the usa. Still in shrink wrap.
denali804
This is a brand new stetsom 2k6d. Still in shrink wrap and new in the box with manual and cord to strap 2. I do have a second one that is not new in the box but is in perfect condition that i can also sell. NO TRADES
specs from stetsom's site
Channels: 1
RMS Power @ 13.8V
Mono 4 Ohms: 2200 Watts
Mono 8 Ohms: 1200 Watts
RMS Power @ 12.6V
Mono 4 Ohms: 2150 Watts
Mono 8 Ohms: 1050 Watts
Minimal Input Impedance: 0,2V
Total Harmonic Distortion:
Signal to Noise: > 90 dB
Crossover Frequency LOW PASS: 50 to 15 KHz
Frequency Response: (FULL RANGE) 20 Hz to 15 KHz (-3dB)
Input Tension: 9 to 16V
Power Consumption: 3,3 to 240 A
Dimensions : 70 x 280 x 330 mm
Weight: 7,0 Kg.
I had the other 1 running 1 ohm daily with no problems what so ever. I don't think they recommend to go under that but I believe that some people have run them at .5 ohm daily without a problem(i wouldnt try .5 but can say 1 ohm works great) And I couldn't sell my 2 for less then you could get a used 7k for so that probably wouldn't make much sense for you. I couldn't sell both for under like $1100 and I would be losing money.
i was told 4000 but ive never actually tested it. The 2k6 replaced a american bass 200.1 which is rated conservativly at 3000 at 1 ohm and the 2k6 was just as loud if not louder. I was also told by a few technicians that the ab 200.1's do closer to 3800 watts at 1 ohm. I think that these are great little amps if you need a small footprint.
denali804
denali804
parts unknown
Beerdrnkr
