Soundstream Tarantula T4 12's (Pair) $250 for the pair or $130 each shipped. BNIB
* Sensitivity: 89 dB
* RMS Power Range : 900 Watts
* Peak Power Handling: 1800 Watts
* Impedance: Dual 1 Ohm
* Low Frequency response: 25 Hz
* High Frequency Response: 1700 Hz
* Diameter: 12 Inch
Features
* RMS POWER (WATTS) : 900
* VOICE COIL DIAMETERS (INCHES) : 3.0
* MAGNET WEIGHT (Oz.) : 200
* FREQ. RESPONSE (Hz) : 25 - 1.7k
* Fs (Hz) : 36.5
* Qes: 0.414
* Qms: 3.584
* Qts: 0.371
* Vas (Ft3) : 1.03/29.27 liters
* Xmax (INCHES) 0.63
* SPL (dB) : 89
* HOLE SIZE (INCHES) : 11.25
* WOOFER DEPTH (INCHES) : 6.1
* RECOMMENDED ENCLOSURE (Ft3) : Ported 2.2
* RECOMMENDED ENCLOSURE TYPE : Vented
* AEROPORT DEMENSIONS (INCHES): 4 x 7.5(1)
* Cast Aluminum Basket
* Dual 4-Layer, 1-ohm Voice Coils
* Cloth Laminated Paper Cone with MD6 coating
* Stone Gray Finish with Diamond Cut Edge
* Hi Arc, High Excursion Surround
* Chrome Plated Back-plate
* Low Carbon Top and Pole Piece
* Triple Stacked Magnet Structure
* Vented and Extended Pole Piece
* Black Progressive Roll CONEX Spider
* Woven Tinsel Leads
* Gold-Plated Binding Posts
* BAEISV Hybrid Voice Coil Former
* C- Lock Rubber Gasket
* Rubber Magnet Cover
* Wood Packing Crate with Chrome Appointments
* Priced per Speaker
2 Used Soundstream Van Gogh 12's $80 each or $150 for the pair shipped
Proprietary Cast Aluminum Basket
UDV Cooling Technology
Low Distortion Nomex/Honey Comb Cone
Black Progressive Roll Conex Spider
C-Lock Rubber Gasket
XLS Santoprene Surround
Dual 4-ohm Voice Coil
2.5” TIL Glass Fiber Coil Former
Woven Tinsel Leads
Vented & Extended Pole Piece
Low Carbon Top & Bottom Plate
Rubber Magnet Cover
Specifications
RMS Power (Watts) 600
Voice Coil Diameter (Inches) 2.5
Magnet Weight (Oz.) 120
Freq. Response (Hz) 22 - 1.2k
Fs (Hz) 29.0
Qes 0.474
Qms 8.032
Qts 0.448
Vas (Ft3) 1.81/48.49 liters
Xmax (Inches) 0.649
SPL (dB) 87
Hole Size (Inches) 11.25
Woofer Depth (Inches) 5.9
Recommended Enclosure (Ft3) 0.6/0.8
Recommended Enclosure Type Sealed
* Diameter: 12 Inch
Features
* Fs (Hz) : 36.5
* Qes: 0.414
* Qms: 3.584
* Qts: 0.371
* SPL (dB) : 89
Woven Tinsel Leads
Rubber Magnet Cover
Specifications
Fs (Hz) 29.0
Qes 0.474
Qms 8.032
Qts 0.448
Xmax (Inches) 0.649
SPL (dB) 87
