BNIB Soundstream DTR1.3400D $350 shipped
KnightWhoSaysNI
It's puuuurrrrrrrfect!
Power Output:
2200W RMS x 1 @ 1 Ohm
3400W RMS x 1 @ 0.5 Ohm
General Features:
Full MOSFET Power Supply
The worlds first vertical automotive stereo amplifier
Double side PCB and SMD components
LED power (green) and protect (red) indicators
Monoblock operation
Gloss black finish w/ brushed accents
Dash mounted remote gain control
3-Way System Protection circuitry (thermal, short, impedance)
Heavy duty aluminum alloy heatsink for extreme heat dissipation
Nickel-plated RCA level inputs
Nickel-plated screw terminals
Variable high-pass filter (10-50 Hz)
Variable low-pass filter (40-220 Hz)
Subsonic Filter (10-50 Hz)
Bass boost frequency: 30-90 Hz
Bass boost level: 0-12 dB
Signal-to-noise ratio: >85 dB
THD (Total Harmonic Distortion): 0.5%
Damping factor: >200
Frequency response: 10-220 Hz
Dimensions: 17-3/4"L x 3-5/16"W x 7-1/2"H
$350 Shipped
included
Does it actually do that power at 1 and .5 ohms? Any clamped numbers on it? Just seems like a large jump from 1 ohm to .5 ohms on this board! Nice amp indeed though!
V.
V.
there are clamp results on caco. If I remember correctly it did around 2500 @ a little over 1ohm with lower voltage. So it should do rated pretty easily. I would provide a link but I'm on my phone. Google "Sound stream dtr3400 and you should come up with the caco thread.
Sorry about cluttering your thread OP, but maybe this will help your sale. I want it but can't spend the cash at the moment.
KnightWhoSaysNI
KnightWhoSaysNI
Oregon
Mitch86
