Sold BNIB Profile AP600, AP1040, ID12v3 d2
dco
MN
Hi everyone,
I bought the amps a while ago and opened the packages to look at them, but I never got around to installing them. They have never seen power.
AP 600 - $70 Shipped
Specs:
2-channel car amplifier
100 watts RMS x 2 at 4 ohms (150 watts RMS x 2 at 2 ohms)
300 watts RMS x 1 bridged output at 4 ohms (4-ohm stable in bridged mode)
variable filters (low-pass from 50-250 Hz, high-pass from 80-1200 Hz, at 12 dB per octave)
variable bass boost (0-12 dB at 45 Hz)
stereo or bridged mono output
Tri-way capable (Tri-Way crossover required)
preamp- and speaker-level inputs
preamp outputs
fuse rating: 20A x 2
8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
10-11/16"W x 2"H x 10-5/16"D
AP1040 - SOLD
The ID12 is also BNIB and opened only to look at. However, I bought this during the winter (I'm in MN) and it was below zero when the UPS guy delivered it. He dropped the package on the magnet protector and the protector came off (basically just glue holding the plastic to the magnet which can be fixed easily). The sub works perfectly otherwise. I will discount this because of the cosmetic issue.
ID12V.3 d2 - $85 shipped
Specs:
Nominal Impedance (IMP) 1/4 ohms
DC Resistance (Re) .98 / 3.8 ohms
Resonant Frequency (Fs) 20.7 Hz
Electrical "Q" (Qes) .412
Mechanical "Q" (Qms) 3.80
Total "Q" (Qts) .372
Equivalent Volume (Vas) 5.71 cu. ft.
One Way Linear (Xmax) 17.0 mm
Cone Area (Sd) 545 cm2
Sensitivity (Spl) 88.6db
RMS Power Handling (Pwr) 50 to 400
Speaker Displacement .07 cu. ft.
Everything:
I will consider all reasonable offers. Shipping included to CONUS, will be more otherwise. Thanks!
thanks for the bump blaze. These really are good budget amps.
I want that 600 right now and i'd buy it but I overdrafted my checking twice and got screwed outta $70 bucks //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif I get paid Tuesday if it's here then consider it sold.
I'd also like to have the ID, can you just glue the magnet cover on with gorilla glue or what would be best? I know the woofer builders on here can fix it in a flash but me on the otherhand...... //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif Lol
Profile's are solid budget amps I have had well over 5 of them.....I want that 600 now to power my Single 4 Ohm Jl W1 12'' to go in my beater car....I'll see if you have this in a few days still. Bump for good products.
I agree they are not a bad amp at all. Installed 4 of them and all worked very well.
blaze, the magnet protector looks like it was glued on in the first place. I'm pretty sure some glue would do it. I think the impact and the cold weather contributed to it coming off. In any case, check back with me tuesday if your interested.
Yeah,
i was going to use the AP1040 to run a 2 way active front and the AP600 to the sub. A real budget system. In fact, I'll knock off a few bucks if you buy it all. $230 for the whole package.
dco
dco
MN
dco
