Sold BNIB LA Storm X1.525C 5 1/4" Comps
clbolt
I'm Bad, I'm Nationwide.
I have a brand new set of Lightning Audio Storm X1.525C 5 1/4" components. These are the most expensive LA comps ever, and were part of the same series as the TC-built Storm subs (the baskets on these mids match the ones on the Storm subs). They're exotic for LA; not only do they have titanium tweeters, but the mids have titanium cones and solid aluminum phase plugs. These also have some massive bi-ampable passive crossovers. The grills are black chrome with a brushed aluminum ring, and the tweeter mounting hardware is black chrome as well. If the only Lightning Audio gear you've ever seen came from Wal-Mart, then you've never seen anything like these. They're rated at 100w rms and 300w peak.
Here are the complete specs:
Nominal Diameter: 5.25"
Nominal Impedance: 4 Ohms
Frequency Response: 70Hz- 20kHz
Fs (Hz):73
Sensitivity (SPL@ 1w/1m): 89.6dB
RMS Power Handling (watts continuous): 100
Power Handling (watts maximum): 300
Mounting Diameter (in): 4 11/16
Mounting Diameter (mm): 119
Mounting Depth (in): 2 1/4"
Mounting Depth (mm): 57
Tweeter
Nominal Diameter (in): 1.0"
Nominal Impedance (ohms): 4
Frequency Response: 2.5kHz- 20kHz
Fs (kHz):2.5
Sensitivity (SPL@ 1w/1m): 91dB
RMS Power Handling (with recommended filter network) 100 Watts
Crossover
Type: 2-way
Crossover Frequency: 5.4 kHz @ 4 ohms
Crossover Slope: 12dB/octave High-Pass
12dB/octave Low-Pass
Filter Q: 0.707 (Butterworth)
Tweeter Protection: Optical Compression
Dimensions (inches): 5 1/8" (W) x 6 3/16" (D) x 1 9/16" (H)
This set includes flush and surface mounts for the tweeters.
$125 shipped CONUS, PM if you're interested.
If you've never seen the LA Storm comps, do a little research on them. These are some serious drivers that Fosgate happened to hang the Lightning Audio brand on. The bare mids are worth the price of admission plus some.
I didn't realize how little was published about these online, so here are the specs from the manual:
Fs (Hz):73
Tweeter
Fs (kHz):2.5
Crossover
Type: 2-way
clbolt
clbolt
Arkansas
bernser1er
