Features and Benefits
KX Amps offer all the flexibility and power you need to keep your system pumping. They’re the amps you turn to when you’re looking for something to hold up under extreme temps and conditions.
The multi-channel amps give you twice the power and twice the control. That means you can push your entire system with one of these bad boys!
Features
• Low Impedance Operation: Stable into 2 ohm stereo or 4 ohm mono loads.
• SORT Protection Circuitry (Short circuit, Over-voltage, Reverse polarity, Thermal): Protects amplifier from accidents and undesired operation.
• MOSFET Power Supply: Provides high efficiency operation.
• KickBass Variable bass boost circuit which provides up to 18 dB of boost at 40 Hz.
• Built-In Variable Crossover: 12 dB High pass or Low pass variable from 50-200 Hz. Defeatable for full range operation.
• High & Low level inputs Allows connection to various sources such as: aftermarket stereo, factory radio, DVD Player, Video Cassette Player, etc.
• Custom tooled gold plated connectors Assure maximum power transfer and damping.
• SAMS (Stereo And Mono Simultaneously) Amplifier will operate into a bridged mono load and a stereo load at the same time.
• Remote Bass Level Control Dash mounted for maximum control.
• EndKaps Cast aluminum, custom, removable covers to protect and hide all your wiring connections to the amplifier. Can be prepped and painted any custom color you choose.
RMS Power
• @ 14.4V, 4W Stereo,
• @ 2W Stereo,
• @ 4W Mono,
• @ 12.5V, 4W Stereo, 0.085% THD+N: 4 x 70
• @ 2W Stereo, 0.5% THD+N: 4 x 135
• @ 4W Mono, 0.5% THD+N: 2 x 250
Specifications
• Height: 2.5 inches / 6.35 centimeters
• Width: 10.125 inches / 25.7 centimeters
• Length Without EndKaps: Subtract 5” / 12.7cm from chart above
• Length with EndKaps: 22 1/2” (57.15cm)
• Frequency Response: 20 Hz - 20 KHz, + 0, -1dB
• Input Sensitivity: 170 mV - 5 V low level, 340 mV - 10 V high level
• Signal-to-Noise Ratio: >95 dB, a-weighted, re: rated power
• Electronic Crossover: Variable high or low pass, 50 - 200 Hz, 12 dB/octave
• KickBass Boost: Variable 0 to +18 dB boost @ 40 Hz
