Fusion PowerPlant FP-1404 4-channel Amp. I also have the heatsink links for these to make them look like one big amp (see pics). I will include one for free (a $44.95 retail value) with the purchase of the 2 FP-600D amps. I will include 2 free links (a $89.90 retail value) with the purchase of all 3 PowerPlant amps that I am selling.
Specs:
CEA 2006 Compliant Amplifier Ratings
12.6 Volt Power Output Specifications
95 WRMS X 4 @ 4 Ohms and ≤ 1% THD+N
150 WRMS X 4 @ 2 Ohms and ≤ 1% THD+N
300 WRMS X 2 @ 4 Ohms and ≤ 1% THD+N
14.4 Volt Power Output Specifications
130 WRMS X 4 @ 4 Ohms and ≤ 1% THD+N
210 WRMS X 4 @ 2 Ohms and ≤ 1% THD+N
425 WRMS X 2 @ 4 Ohms and ≤ 1% THD+N
Bandwidth 10Hz – 40kHz
Signal to Noise >95dB
Fuse Rating 3 x 30A
Separation >60dB
Input Sensitivity 300mV-8V
LP Variable Crossover 40 Hz – 160Hz @ 12 dB / octave
HP Variable Crossover 40 Hz – 600Hz @ 12 dB / octave
Variable Bass Boost 0dB + - 18dB Gain @ 45 Hz
Variable Subsonic Filter 20 Hz – 55Hz @ 18dB / octave
Input Impedance 20KΩ
Damping Factor >200
T.H.D 0.05%
Dimensions D 2.26" (57.5mm) L 18.11" (460mm) H 8.66" (220mm)
2 Ohm Stable MOSFET Amplifier Design
CEA 2006 Amplifier Power Standard Compliant
FUSION Regulated Amplifier Technology (F.R.A.T)
FUSION Intercooled Semi-conductor Technology (F.I.S.T)
FUTRANZ Efficient Heat Sink Transfer Technology
Gold Plated 4 gauge Power and Ground Connections
Gold Plated 8 Gauge Dual Speaker Output Connections
Gold Plated RCA Audio Input
Gold Plated RCA Audio Output for Multi-Amp installations
Amp is brand new in the original box with all OEM accessories: manual, mounting hardware and Fusion sticker.
($240) $225 (original street value of $399 - $549) + 1/2 of actual shipping; deals given on multiple purchases; PM me for payment details/other shipping options. Buy with confidence: see my signature (below) for references. Thanks for looking...rock on! Will take an Eclipse ECL-SC1 as partial payment.
Specs:
Fuse Rating 3 x 30A
Separation >60dB
Damping Factor >200
T.H.D 0.05%
