Plans have changed for me and i'm selling a BNIB DLS RA10 and BNIB DLS RA20 reference amplifiers. These are a perfect match for a pioneer p880prs headunit with the brushed aluminum face. My plan was to match everything in a brushed aluminum look including sub but plans have since changed and these amps are for sale. $485 shipped for both of them or $450 local pickup. At this time only looking to sell as a combo unless i find buyers for each. This would make one sweet setup and this is a great deal if you do a search on them. PM me your email address for pictures. Specs below.
DLS RA10
Amplifier class AB
Mono bridge mode 4 ohm N/A
Output power in 4 ohm 300 W
Output power in 2 ohm 500 W
Output power in 1 ohm 780 W
Damping factor > 200
S/N ratio, A-weighted > 100 dB
Frequency range 10 Hz - 125 Hz
Input sensitivity 0,5 - 8 V
Low level output No
Input impedance > 10 kohm
Input impedance, high level 330 ohm
Phase control for subwoofers 0-180 degrees variable
High pass filter Subsonic 25 Hz / 18 dB slope
Low pass filter 40-125 Hz / 12 db slope
Grand bass filter 0-18 dB @ 40 Hz
High level input with auto start Yes
Remote phase shift control Yes
Remote bass level control Yes
Integrated fan Yes
Power consumption (idle) 0,6A
Power consumption (max) 120 A
Rec. power cable Minimum 2AWG / 33 mm2
Fuses 4 x 30 A
Dimension (W x D x H) 359 x 245 x 59 mm (14,1 x 9,65 x 2,33 inch)
Weight 4,3 kg ( 9,5 lb)
DLS RA20
Number of channels 2
Amplifier class AB
Output power in 4 ohm 2 x 130 W
Output power in 2 ohm 2 x 200 W
Mono bridge mode 4 ohm 440 W
Frequency range 10 Hz - 50 kHz
Input sensitivity 0,2 - 7 V
High pass filter 20 - 150 Hz
Low pass filter 40 - 125 Hz
Low level output No
Power consumption (idle) 0,6 A
Power consumption (max) 50 A
Rec. power cable Minimum 4AWG / 21 mm2
Fuses 2 x 25 A
Weight 3,8 kg ( 8,4 lb)
DLS RA10
Amplifier class AB
Low level output No
Integrated fan Yes
Fuses 4 x 30 A
DLS RA20
Amplifier class AB
Low level output No
Fuses 2 x 25 A
