I've got a brand spanking new DLS Ultimate A3 amplifier "Twin Mono" for sale. Im taking a different route with my system (via a IA 20.1), so this has to go. These are DLS's flagship line of amplifiers, using only pure AB technology. The DLS Ultimate "A" amps are some of the best in the business, comparable to Zapco C2k and Arc XXK lines. It is truly a beautiful amplifier, none of the pics do it justice. I believe Scott Bulwada exclusively uses several of these A3s in his award winning SQ vehicle.
ULTIMATE series A3 is a powerful two-channel amplifier. A true, dual mono block with separate power sources that provides power output of 2 x 150 Watts with 4 ohm stereo and 550/870 Watts with 4/2 ohm mono. The amplifier is 1 ohm stable.
Built-in fan control. Built-in, variable 50-125 Hz switchable low-pass filter for subwoofers. Built-in variable 20-200 Hz. high-pass filter that can be used as a subsonic filter or high-pass filter for front systems. Dual power terminals where you can connect dual power feeds or a DLS Power Cap. Button for switching phases when you use it as a subwoofer amplifier.
RMS output per channel at 13,8 volts, 20 Hz - 20 kHz ,
Mode: AB
Number of channels: 2
Output power in 4 ohm: 2 x 150 watt
Output power in 2 ohm: 2 x 270 Watt
Output power in 1 ohm: 2 x 425 Watt
Output power in 4 ohm bridge mode: 550 Watt
Output power in 2 ohm bridge mode: 870 Watt
Output power in 1 ohm bridge mode: 1200 watt
S / N ratio, A-weighted: > 100 dB
Damping factor: > 200
Input impedance: > 10 kohm
Input sensitivity, variable: 0,2 - 7 V
Filter, highpass, variable: 20 - 200 Hz
Filter lowpass, variable: 50-125 Hz
Terminal for external cooling fan: Yes
Double DC-inputs: Yes
Phase shift button: Yes
Current draw, idle: 1,1 A
Current draw, maximum: 140 A
Dimensions W x D x H: 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Weight: 6,2 kg ( 13,67 lb)
(briefly ~1-2 minutes out of the box, to prove that it is indeed the A3)
PRICE $450 + S/H/PP
references:
just sold a bnib DLS A5 amplifier on diymobileaudio.com to 1darrely (A5 is currently en route to hawaii)
sold a pair of bnib Adire Kodas and Pioneer Premier Touchscreen over here
Mode: AB
PRICE $450 + S/H/PP
references:
