BNIB Dayton Audio DS175-8 6-1/2" Designer Series Speakers
Beerdrnkr
BNIB pair of Dayton Audio DS175-8 6-1/2" Designer Series Speakers
Brand new in box. Just took out for photos.
The Designer Series by Dayton Audio was developed specifically with the speaker designer in mind. It is an affordable, attractive line of drivers that puts performance first. Careful engineering ensures that each speaker in the series is capable of handling full rated power at the lowest possible frequencies—without exceeding Xmax.
These speakers combine useful performance parameters with elegant style. Carefully optimized to provide superb audio reproduction when incorporated into a wide variety of enclosures and alignments, the Designer Series transducers put a beautiful face on audiophile excellence.
PRODUCT SPECIFICATIONSPower Handling (RMS) 70 Watts power Handling (max) 140 Watts Impedance 8 ohms Frequency Response 40 to 4,500 Hz Sensitivity 88.6 dB 1W/1m Voice Coil Diameter 1.40" Magnet Weight 33 oz.
THIELE-SMALL PARAMETERSResonant Frequency (Fs) 40.9 Hz DC Resistance (Re) 5.6 ohms Voice Coil Inductance (Le) 1.12 mH Mechanical Q (Qms) 1.82 Electromagnetic Q (Qes) 0.37 Total Q (Qts) 0.30 Compliance Equivalent Volume (Vas) 0.61 ft.³ Mechanical Compliance of Suspension (Cms) 0.74 mm/N BL Product (BL) 9 Tm Diaphragm Mass Inc. Airload (Mms) 20.5g Maximum Linear Excursion (Xmax) 5.25 mm Surface Area of Cone (Sd) 128.7 cm²
MATERIALS OF CONSTRUCTIONCone Material Coated Paper Surround Material Rubber Voice Coil wire Material Copper Voice Coil Former Aluminum Basket / Frame Material Steel Magnet Material Ferrite
MOUNTING INFORMATIONOverall Outside Diameter 6.91" Baffle Cutout Diameter 5.67" Depth 3.17" # Mounting Holes 5
Dayton Audio DS175-8 6-1/2" Designer Series Woofer
Partsexpress sells them for $35ea. I'll sell them for $55 shipped.
Untitled by Beerdrnkr, on Flickr
Open to any trades? I have some Onkyo home audio speakers, Polk subs, JVC 5.1 avr, and numerous cable (HDMI, optical digital audio,etc.) Also have linksys router and other misc computer stuff, Sony compact photo printer, Kodak digital camera, etc.
Bryan
I'm open to trades but I don't really need any of those items. I just picked up a new home theater and I'm still working on buying some emotiva pieces. Thanks though.
I'm either buying a monoblock, 4 channel amp, or some 6.5" speakers on tuesdayish.. I'm considering these but being honest i'm scared it wont fit in my door cause its so **** big!!! Do you need external crossovers for these?
To be honest, they are pretty big. Yes, you will need an external xover for these, but like I said, if you can fit them and grab a set of decently priced tweeters like Vifa or Daytons and go active, you'll have a better setup than a lot of component sets out there.
I gave a buddy of mine a set of the Dayton classics w/ a set of Vifa tweets and he picked up a Pioneer 80prs to go active and after I did some tuning for him I was really surprised at how well that setup sounded.
Beerdrnkr
Beerdrnkr
San Diego
Beerdrnkr
