Sold BNIB AudioMatic 2 Channel Amp and 5.25" Speakers...
clbolt
I'm Bad, I'm Nationwide.
I have a brand new AudioMatic Sound AG-2880 amp for sale. According to the box it puts out 105 watts RMS x 2 into 4 ohms, 160 watts x 2 into 2 ohms, or 320 watts x 1 into 4 ohms. The S/N ratio is 98db, and thd is .05%. It has sub and high pass crossovers. I don't know anything about the brand other than it's a cosmetic knockoff of a McIntosh, complete with top-mounted dual power meters. It still has the plastic on the top panel. The dimensions are 11.75" x 8.5" x 3". It's a good looking amp, one that'd display nicely. The price is $100 shipped CONUS via UPS ground.
I also have a pair of AudioMatic sound 5.25" coax speakers that were apparently production samples. They're BNIB, but they're actually Signat SIGNAT SC-1300 speakers with the box turned inside out, a plain white sticker on the back of the magnet, and AudioMatic grills.
SC Coaxial-2-way speaker system: the audiophile top class. The modern, high-tech, slim construction allows an easy and perfect installation in many original mounting locations with an excellent appearance. The lightwieght and stiff membranes guarantee an unaffected reproduction of acoustic signals. SIGNAT SC speakers use an injection carbon polypropylene cone, with almost ideal characteristics. The signal is reproduced effectively without any distortion or unwanted slf-oscillation. SC speakers display a porperly balanced sound character along with refined highs. A strong ferrite magnet delivers a solid drive; the voice coil, equipped with heat-resistant wire, can easly be combined with power amps.
The natural, warm and never aggressive sound or the tweeter captivates any listener. These are typical characteristic of a silk dome. The ferrofluid-cooled voice coil and the neodymium magnet (ten times stronger than any conventional magnet of the same size) from the tweeter`s fundamental drive, which tolerates high loads even with impulse peaks and continuous operation.
SC 1300
Type Coaxial 2-Way
System size
Midwoofer: 130mm
Tweeter : 13mm
Membrane
Midwoofer: ICP
Tweeter: silk
Surround: Butyl rubber
Basket: SIGNAT blue steel
Gasket: foam
Magnet
Woofer: ferrite8 Oz, 80x40x15mm
Tweeter: neodymium
Voice coil: 25,5mm
Terminal: 4,8x0,8mm 2,8x0,8mm Gold plated
Crossover slope LPF:-/HPF 6 dB
Grille: Metal mesh (SIGNAT)
Mounting material: included
Technical data:
Music power: 2x80W
Nom. power: 2x40W
Nom. impendance: 4 Ohm
DC resistance: 3.7 Ohm +/-15%
Frequency response (MSPL-10 dB): 60 Hz - 22 kHz
Recommended frequency range: from 60Hz or full range
Free air resonance frequency: 100 Hz, +/-20%
Mean sound/ pressure level: 88 dB/W/m, +/- 3dB / +/- 3dB
Qts: 1,2
Vas: 6,1 ltr
Xmax: 1,5 mm
Mounting diameter: 118 mm
Mounting depth: 61 mm
Anyway, they're new, 40 watts RMS, 80 watts peak, poly cones, and rubber surrounds. $40 shipped CONUS. PM if you're interested.
clbolt
clbolt
Arkansas
clbolt
