Arc Audio XXD5080 5-Channel Class D High Performance Car Audio Amplifier
It is a Brand New Refurb that I purchased from Ace Electronix. I sold my car and have no use for it now. It has never been used and was only taken out of the box for pictures. Please let me know if you have any questions or need any more pics/info.
It DOES come with the Bass Knob Accessory, also.
I apologize for the quality of the pics as my phone takes poor photos but I assure you that the Amp looks brand new and everything is in perfect condition.
Thanks,
Andrew
Product Details and Features:
Full Range Class D Design
5 Channel all-in-one configuration for a single amp installation solution
Phillips Technology Chip Based Class D Output Technology
Designed by ARC Audio in-house engineering staff
High frequency switching power supply allows for greater separation from audible listening frequencies increasing sound quality and lowering THD
Input inductor power supply isolation protects from unwanted interference in AM/FM reception
Extremely low voltage chip based soft turn on circuit
High speed ultra low ESR output network
Ultra Low ESR high capacity power supply storage bank
Secondary dedicated Low ESR capacitor bank for output devices
Optically isolated power supply allows for increased sound quality and lower THD ratings by isolating the power supply from the input stage.
dual side FR4 coated PCB
Embedded protection circuits including – Thermal Limit, Current Limit, Thermal Rollback DC Offset, Reverse Polarity, and Overvoltage
Secondary side plate dual color Power/Protection LED
Block style high grip termination blocks
Concealed hidden mounting points for a visually screwless installation
Illuminated (blue) terminal block insulators
Illuminated Mono Chrome LCD light up logo display on top of amp
Selectable Full Range/High Pass Variable 65Hz – 250Hz 12dB Front and Rear Channel crossovers
Subwoofer channel 5 selectable input switch
Includes a remote subwoofer level control
Subwoofer channel 5 Variable Low Pass 12dB 50Hz – 250 Hz crossover
Subwoofer channel 5 On/Off selectable 12dB bass boost
Power output RMS @ 4 ohms 4 x 80 watts / 1 x 200 Watts
Power output RMS @ 2 ohms 4 x 100 watts / 2 ohms not recommended on sub output
Power output RMS @ 4 ohms bridged 2 x 200 watts channel 1-4 bridged
Transient Distortion (100 watts) Frequency Response 20Hz - 20 KHz
Signal to Noise Ratio >79dB
Bass Boost +12db@45Hz
Crossover (Butterworth) High (65Hz - 250Hz) / Low (50Hz - 250Hz)
Gain Range .25V - 4.0V
Size 10 3/4" (L) x 7 1/8" (W) x 1 7/8" (H)
$150 Shipped
Item will be shipped via USPS and I will ship it the same day that payment is received w/ tracking information if it happens before the post office closes. Otherwise, it will be shipped out the next morning.
Thanks,
Andrew
$150 Shipped
