Blue Sea 12 Circuit power and ground distribtuion block-takes normal fuses
durwood
Brand New Blue Sea 5026 12 Circuit Fused and Ground distribution block.
It's awesome because it takes normal ATO/ATC fuses you can find anywhere. Screws are Philips head so no need to dig out that one hex key. Cover+labels. Would be nice an clean show piece for install or use it in your boat.
I was going to use it but never got around to installing it and trying to raise some cash to fund a different build.
$35 shipped
ST*Blade Fuse Block With Cover - 12 Circuit with Negative Bus - PN 5026 - Blue Sea Systems
Dimensions
6.472" x 3.315" x 1.518"
#8 Screws
#10 power studs
Fuses you can buy at any autoparts, gas station, etc. The ATC type. If you blow one, it's not like it's an easter egg hunt to find a place that carries them. Plus if you have small electronics that only need 1 or 3amp fuses this will accommodate
durwood
durwood
St. Charles, IL
Sub Woofin
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
