blue green white and all this
Sorry....the first picture is the post that goes to the pos. on your battery.You can also see the harness I made so I didn't have to cut the factory one.The ground is on the bottom I just used a ring terminal and slid it on the bolt as I threaded it in the bottom braket.There isn't a particuliar spot to mount the ground on this specific model alt it just needs to be in contact with the case for the best ground.Then run the ground wire to the frame of your vehicle you should also run a neg. wire from the battery's neg post to this same spot.The second picture is my regulator.The factory ECU controls the voltage in most chrysler vehicles at around 13.5-13.8v.So I got the regulator to get up to 14.7v.And if I want I can now run 16v.
pioneerpimp
pioneerpimp
IL
audioarsonal
