1. Products:
jbl bpx 1100.1
jbl px 300.4
phoenix gold xenon 100.4
custom 12 inch scott sackett built tc sounds with custom 3hp motor
boss audio clr70 amp zed built or designed... not sure which has great sq
2. Specs:
jbl bpx 1100.1
* Power Series Class D Monoblock Car Amplifier
* RMS Power Rating:
o 4 ohms: 1141 watts x 1 chan.
o 1 ohm: 1022 watts x 1 chan.
* Max power output: 1312 watts x 1 chan.
* Current Servo Circuitry with Crown Technology
* High-efficiency switching power supply
* Wired remote bass level control included
* LED I-E/OPT, power, and protection indicators
* Tuned Bass EQ (adjustable bass boost)
* Parallel/bridgeable operation
* Preamp RCA outputs
* Dynamic Bass Optimization (DBO) - This provides variable filtering with adjustable "Q" below 100Hz, far beyond conventional "Bass Q" circuits, by allowing the low-frequency output to be optimized for specific subwoofer applications
* DC, thermal, voltage, overload, and short circuit protection
* Die-Cast Aluminum Chassis with Top Plexiglas Viewing Window
* Variable low-pass filter (32-320 Hz, selectable 12 or 24 dB/octave)
* CEA-2006 compliant amplifier
* Frequency response: 21-320 Hz
* Dimensions: 17"L x 12-1/4"W x 2-9/16"H
* 4-gauge power and ground leads recommended. Contact us for information regarding a discount on a select amplifier kit when purchased together.
jbl px 300.4
* 300 watts, Power Series 4-Channel Amplifier
* RMS Power Output:
o 4 Ohms: 123.5 watts x 4 chan.
o 2 Ohms: 169 watts x 4 chan.
o 4 Ohms Bridged: 358 watts x 2 chan.
* Full MOSFET Power Supply
* "Direct Connect" Terminal Block Allows for 4 or 8 Gauge Power Wire
* Dual Variable High-Pass / Low-Pass Crossovers (32-320 Hz)
* Selectable Crossover Slope (12 / 24 dB)
* Dynamic Bass Optimization (DBO) Subsonic Filter
* Preamp Outputs
* CEA-2006 Compliant
* S/N Ratio: 76.64 dB
* Dimensions: 17"D x 12-1/4"W x 2-9/16H
custom tc sounds 12, d2 voice coil ( actually quad 1ohm 8layer coil that is wired to 2 terminals) i have had it on a saz1500d at 1 ohm, no stink nothing, guessing about 2000rms shouldnt be a problem. more info can be found here.
TC Xmas Gift LOL! - Car Audio Classifieds
*variable thermal feedback controlled fans
*24dB Linkwitz-Riley low pass and subsonic filter
*optimized for any impedance load
*Tried and true triple Darlington output stage
*Buffered RCA full range thru output
*Remote Monitoring Display (RMD) port
*Low Pass Level control ready (LPL-44)
*100W x 4 (4-1 ohm stereo)
*200W x 2 (8-2 ohm bridged)
Boss Audio clr70
Rated at: 150x2, and 300x1
3. Descriptions/Condition of all items:
jbl bpx 1100.1 9/10 costmetic ( has a few very light scratches) works 100%
jbl px 300.4 9/10 costmetic ( has a few very light scratches) works 100%
phoenix gold xenon 100.4 8/10 cosmetic ( missing the rubber speaker and power covers as most 100.4) works 100%
12inch tc sounds excellent condition. i dont think its even broken in yet, still stiff. coil is nice copper color. basket has a few marks from mounting which can be seen in the picture. works 100%
boss audio clr 70. 8/10 plexi has some scratches, works 100%
4. Total Price: : price for everything is 1330 shipped within the 48. of course price is negotiable here is how it breaks down into individual items
jbl amps combo- 650 shipped
tc sounds sub- 450 shipped
phoenix amp- 130 shipped
boss clr70- 100 shipped
prices are negotiable, some of them seem a little high but again they are negotiable. local pickup is more than welcome. i will give a great price for local. reason im selling most of my stuff is that i will be putting an lt1 in my camaro so it will be out of commission for a while. so i will have no use for my audios in the mean time.
5. Pictures:
jbl bpx 1100.1
jbl px 300.4
2. Specs:
jbl bpx 1100.1
* RMS Power Rating:
jbl px 300.4
* RMS Power Output:
* Preamp Outputs
Boss Audio clr70
5. Pictures:
