blown voice coil
I dont think you can recone a CVR....you knew it wasn't working huh?
Seriously I think if you hook the + on the sub to the + on your Kinetik 2400 and the - on the sub to the tip of your penis and run a jumper wire from the - on the battery to your nipples it will fuse the voice coil back....don't forget to be in the shower when you do this
I dont think you can recone a CVR....you knew it wasn't working huh? Seriously I think if you hook the + on the sub to the + on your Kinetik 2400 and the - on the sub to the tip of your penis and run a jumper wire from the - on the battery to your nipples it will fuse the voice coil back....don't forget to be in the shower when you do this
I'd say no, actually, since regular water by itself will conduct better than flesh, I'd say to not be anywhere near water. I'd tell him to go near a power station so he can hopefully short out his dick AND get hit by arc lightning ala this:
//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Florida13
www.gatorsportsnation.com
Florida13
Florida
PV Audio
