Hey, i have an mtx 500d that i recently installed in my car. I found out the hard way that having a good ground is very important. It smoked, didn't blow the fuses, and then breathed its last.
this is USA made, high quality, and many of you may know how to fix it. Here is a review that tests it at nearly 900w at 2ohm, and almost 1000w at a higher thd.
http://www.carsound.com/review_archive/amps/500d.html
Frequency Response {4 Ohm IHF Load 20Hz Ref. Crossover @ highest setting): +0dB, –3 dB @ 208 Hz
L/R channel error (max deviation 20Hz to 20kHz): N/A
Signal-to-Noise Ratio {Below Rated Output, “A” weighted}: –121.4 dB
Distortion at Rated Output @ 60Hz: 0.29% @ 500 watts
Output Power [Resistive] {4 Ohms @ 60Hz to 1% THD+N): 535 watts @ 14 volts; 456 watts @ 12.8 volts; 298 watts @ 10.5 volts
Output Power (Resistive) (2-ohm @ 60 Hz to 1% THD+N): 889 watts @ 14 volts; 735 watts @ 12.8 volts; 485 watts @ 10.5 volts
Output Power (Reactive) (2-ohm IHF Load @ 60 Hz to 1% THD+N): 984 watts
Crosstalk @ rated output, 20 Hz to 20 kHz: N/A
Damping Factor, 2 ohms @ 100 Hz: 223
Voltage for Rated Output: 148mV to greater than 20 volts
Idle Current Draw: 1.2 amps
Current Draw @ 1/3 Maximum Power: 32.7 amps @ 296 watts
Efficiency @ 1/3 Maximum Power : 65%
Power-Up Noise: 28.5 dB SPL
Power-Down Noise: 14.4 dB SPL
I would like to get $65 shipped for it. I will get pics up later today.
Thanks!
Thanks!
