c_hayhurst
I just spent the entire day daisy chaining another amp to a delaer-installed amp. After spending the entire day off work, I got it installed and promptly blew the power cable's inline fuse. The dealer installed amp is a DEI Audio 4x50 running 4 Polk Audio speakers with an RMS rating of 60 Watts. That amp and those speakers have been running in my car for the last 3 weeks with no problems. The power cable has an inline 100 Amp fuse within 18" of the car battery.
The power cable from the battery to the fuse block and the ground wire is 4 guage. I use a fuse block for both the ground wire and the power cable. From the power cable's fuse block to each amp is 8 guage, installed by the dealer on the first amp, installed by me on the second amp.
Today, I just daisy-chained an amp to run my subwoofer. It was a Rockford Fosgate T5002, that I bridged to run mono, with a power rating of 500 Wattsx1 channel at an impedence of 2 Ohms. I wired my dual voice coil Resonant Engineering SE series, 600 W RMS, sub down to 2 Ohms (negative to negative, positive to positive, one negative to amp from one voice coil, one positive to amp from the other voice coil). I used Radio Shack RCA cables to link the output of the first amp to the input of the second amp. The speaker wires for the sub are bridged per the instructions on the amp, with 16 guage wire.
Settings on the second amp (Rockford Fosgate):
Infrasonic Filter- OFF
Gain- Maxxed out
Frequency Setting- 40 Hz
Frequency Multiplier- 1x
If I remember correctly, the gain was intially set really low, and the sub didn't sound worth a ****. I drove around with it a few minutes with the gain set low. s a Rockford Fosgate T5002, that I bridged to run mono, with a power rating of 500 Wattsx1 channel at an impedence of 2 Ohms. I wired my dual voice coil Resonant Engineering SE series, 600 W RMS, sub down to 2 Ohms (negative to negative, positive to positive, one negative to amp from one voice coil, one positive to amp from the other voice coil). I used Radio Shack RCA cables to link the output of the first amp to the input of the second amp. The speaker wires for the sub are bridged per the instructions on the amp, with 16 guage wire.
Gain- Maxxed out
If I remember correctly, the gain was intially set really low, and the sub didn't sound worth a ****. I drove around with it a few minutes with the gain set low. While in a parking lot, I increased the gain and let the stereo play with the engine running. It still didn't sound very good. In about one or two minutes, the inline fuse by the battery blew. Neither amps' fuses were blown and neither were the car's fuses blown. The stereo maintained power.
I think the high gain setting blew the fuse, but I am not sure. Can anyone give some insight as to what made the fuse blow? Thanks.
Gain- Maxxed out
Gain- Maxxed out
