Blaupunkt VS. JBL VS. Pheonix Gold Check it out!
  • 1
Daniel
Caraudio.com
863
SFLA
Alright my subs are rated at about 200W rms and i would like to know which sub would be the best for this wattage. i have blaupunkt pcwi1200 subs, TWO of them, and want to know which amp is the best for this sub.
i was lopoking at the JBL 600.1 which would do about 300W x 2 @ 2ohm in parallel
i also found the blaupunkt PA 2150 its specs would be as followed:Blaupunkt PA2150 Amplifier
Super Efficient Class T Design
2 x 200 Watts MAX @ 4 Ohms
2 x 150 Watts RMS @ 4 Ohms
1 x 500 Watts MAX @ 4 Ohms Mono (Bridged)
1 x 400 Watts RMS @ 4 Ohms Mono (Bridged)
2 Ohm Stereo Stable
External High Level Input Adapters
Variable 12 dB/Oct HP/LP Crossovers
Subsonic Filter @ 10Hz
S/N Ratio > 100 dB
Free Color Inserts
Dimensions w/ Housing: 10" x 9" x 2.6"
Dimensions w/o Housing: 9" x 7.5" x 1.8"
3 Year Warranty
The next sub i found was the pheonix gold QX 4150V.2 its a 4 channel amp that does 150 x 2 max power bridged..
which one is my best bet to go for and will sound the best with these subs!?
thnaks again I could not find this product in europe so I will go with this one ...
10
Lookslike the amplifiers recommended should work just fine with Either Chs 1&2 or 3&4 bridged/mono mode/LPF should work just fine as well as using...
16
4K
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
Daniel
Caraudio.com
Daniel
SFLA
Daniel
