first i tried heating it up with a heat gun. that dosnt work to good as the housing and lenses will melt before the glue will. so there are 3 tab on the orange part that hold it inplace so i took a 5/64 drill bit and drilled out the tabs through the top of the lenses. then i stuck some needle nose pliers inside the whole where my turn signal bulb goes. i pulled it over so that i could take some dikes and break it up and pull it out of the hole where the bulbs go. then take some compressed air and a vacume to get all the small particles out. then vuala DIY clearshow did you open the lights? did you bake them to loosen up the glue (i read that a few places) or were there some kind of fastner to take them apart?
let us know //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
the new audi transmission>your lifenot jsut any old auto a tiptronic auto. sure stock to stock the manual will be faster but once i put in a tip chip that bad boy will shift in under .2 seconds. faster than im sure most people acn shift their manuals
