Bigrick31's 04 Sliverado Project Log
ok mr compensationforpenisrick.
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i still love you noobcakes. //content.invisioncic.com/y282845/emoticons/inlove.gif.6846f78f06b405429ef3a00129788a2a.gif
but to clarify, i was not saying it wasnt a cool thing to build, but if you paid a shop to do it, id call you homosexual //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
oh yea built not bought! why pay someone to do it you cant really call it yours. thats lame. i may get help like with welding and stuff just because my friends are a lot better than i am and thats kinda playing with my life so ill have them do it. but im still right in there grinding and cutting and bolting shit on and running wires. hopefully i can get the link system close to done tomorrow.
this is awesome.
thanks! oh yea i forgot to mention to ya guys. so im planning on raising the bed floor as i dont prefer to have a huge hole cut in the center of my bed id rather keep the semi stock look. well we figured what teh hell lets raise it enough so its body droped. then just shim it up for now and later build a new frame under the cab of my truck to do a stock floor body drop there and then just drop out the shims and BOOM!!! body droped B!TCHES!!!!! just gotta figure out if im gunna go to the rocker or the door!!!
Go to the rockers Rick. Save you some headaches down the road.
It is easier to weld in new rockers than it is to have to replace/repair what little bit of metal is left under the doors and the corners when it gets beat up.
Section the gas tank or spend a couple hundred on a fuel cell. I got mine for $150. 15 gallons.
And easy on the built not bought deal. Not everyone has the proper tools and knowledge to set a link system up and it should only be performed by skilled people. So paying someone to keep your vehicle safe and not crashing across medians and slamming into inoccent drivers is worth it.
(my shop does suspensions and body shaving also if in FL //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif)
More pics Rick.
Go to the rockers Rick. Save you some headaches down the road.It is easier to weld in new rockers than it is to have to replace/repair what little bit of metal is left under the doors and the corners when it gets beat up.
More pics Rick.
yea im more refering to the people who pay someone to do their whole truck and then like to talk sh!t about what other people are doing to theirs. thats more who im refering to pics coming later tonight about to go to the gym in a min and then work on the truck
ok only worked on the truck for about an hour tonight by the time i got home from the gym and ate dinner it was 8 but anyways heres what i got
drilled out 8 7/16 holes for my bracket. took like 45 min just to do that!
mounted the compressors on the brackets we welded in
and theres an air bag cut in half :p
Thats *** backwards.
You should use the Slams and cut the contis.
//content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thats *** backwards.You should use the Slams and cut the contis.
lol that slam was worn through. i also have a conti that was rubbed through but the conti are the 4 ply good for like 300psi:fro:
Those compressors look beat up
they are just dirty. i bought them off of my buddy in are club someone hit his truck so i got valves compressors a switch box an air tank and pressure switch for $200 its ok though because im planning on adding in nitrogen so the compressors will be a back up.
Bigrick31
Carpe Diem
Bigrick31
Mid*Cal
MikeyB
