Bigpimpin91's 1988 Bronco II
alright cool, thanks man. and look what i found on craigslist. may have to try and pick it up for like 200 http://detroit.craigslist.org/ele/1202540299.html
I texted you, don't know if you got it.
If that amp still has original packaging, I might be able to swap it for a new one. //content.invisioncic.com/y282845/emoticons/sneaky.gif.7189749b3a3f769e8815b47e8ae87f88.gif
First Burp is 35hz.
Second is 29hz.
Third is 23hz.
Fourth is 33hz. (My Peak.)
Fifth is 34hz.
Sixth is 45hz.
Last one is some bass race practice.
Got a perfect 39.9 and decided to crank it. Forgot I had the Zune turned down. And my drivers window fell down. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
(Soulja Boy - Rubber Bands)
That annoying *** wail is my alternator belt.
V-Belt FTL.
First Burp is 35hz.
Second is 29hz.
Third is 23hz.
Fifth is 34hz.
Sixth is 45hz.
V-Belt FTL.
Thanks to Cr@sh at SMD for the Meter time free of charge.
Upgrades since last time you seen me.
Ran a negative run of 1/0.
Upgraded to 3 G31's.
All 8ga Sub wiring.
Reconed one bad sub.
Re-glued seperated roof braces.
Added second skin to roof. (Not completed in videos.)
Couple More Videos.
Re metered today, no change, but I no longer have a massive roll off after 40hz.
Pretty flat response down to ~25-27hz.
Pulled a 132 @ 14hz.
****ing Gorilla Zoe - Money (35hz FTL.)
Just cruising home, cranked it because I was trying to unwind.
Look in the rear view noticing it seemed to be moving more than usual, and then it fell. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Whats the box tuned to and how much port area? Curious, and I am geting ready for another build!
Box is 9 cubes @ 35hz with 16.4 sq/in a cube.
It's actually peaking below tuning which is quite weird. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Bigpimpin91
King of Low Banging Beats
Bigpimpin91
Taylor, MI
DB-Audio
