Big Question For Ya Pros
undits
Bass 4 Life
ok... i got a couple of questions
i am going to be running on mono amp to two 15'' subs.... i will most likely be getting a HO alt, and doing big 3, and running all 0awg all around, and then hopefully running some comps off their own amp.. basically.. i want to know everything that i will need to buy in order to be good to go
what i am wondering is;
how many fuses will i need?
how many feet of wiring?
what other hardware will i need?
will 8 awg be fine to go from amp to subs?
this will most likely be going into a civiv hatch... if that helps
thanks alot guys
Mow big are the amps as in total rms, If you went with 1/0 to the back to a distro blocvk then 4 to the amp you would only need 1 fuse, my guess on wiring is 15 ft of 1/0 and then 1-3ft of 4awg for your amps. as far as the 8awg wire I wouldn't recommend it I would always recommend you go bigger than you will use incase of upgrading later then you don't have to rerun your wiring. Hope that helps.
undits
Bass 4 Life
undits
Swan Hills, AB
BigOso
