mendon mafia
`94 caprice, 15" Fi BTL
First of all read my sig to see what im working with.
Ok so obviously like the rest of you i want a loud daily system that sounds clean. Everyone tells me i cant have both then i see thor, peas and treossi and others who have loud trunk systems that seem to sound very musical, at least on youtube.
How can i get similar results? I have a pair of rd alpha v3's but wouldnt mind changing if i cant succeed in achieving my goals with these woofers. For power i have an atomic 3000.1 2 spv70's in the trunk, stock batt under hood and a 200 amp alt.
I was always told the larger the box and larger the port area = more output but at what cost? It seems that the large ports have no negative effects in systems like thors and treossi and the internal volumes are pretty much to spec.
When i first bought the subs steve miller told me to do 4 cubes net and ~48" port area tuned to 34hz for BOTH SUBS for sql.
I thought i was going to school on thor and peas and treo using a spec volume and a larger port but i have terrible unloading and distortion in the 45-60hz range. Im currently running my alphas in 2 seperate boxes EACH is 2 cubes @ 37hz w/ 48" of port area. They get pretty loud but unload TERRIBLY in the 45-60 hz range and i need this range to not **** so badly lol. below 45 hz i can thow all the power i have (probably very clipped too) at the subs and they just soak it all up and dont bottom out or anything (until i go far below tuning ~27hz and below)
After trying to find a remedy my issue i had a few people model some boxes for me on bassbox pro. I was told that the best sq (flattest response) box would be 2 cubes net for BOTH subs tuned to 32hz (no port area recommendation) i was told for sql i should go to 3 cubes net for BOTH subs34 hz (no port area recommendation). I was told that the boxes i have them in now modeled poorly but DID NOT account for the issue im having in the 45-60hz range.
I would really like to be able to get louder if anything since im for sure going to build a new box (definitely common chamber) but realize i might have to lose a db or two to get my sq back. I never completely sealed off the boxes from the trunk (even when i was metering) so i will at least be able to gain a bit by doing that.
Any suggestions are much appreciated, thanks
