Big Help Needed Right Here!!!!
krj725
I need to know exactly what amp i need for these subs
**Brand New Kicker DC124 Dual 12" Loaded Vented Comp C12 Subwoofer Box **Dual 12" Vented Enclosure with Kicker Comp Subwoofers **4 Ohm Final Impedance **Peak Power Handling: 600 watts **RMS Power Handling: 300 watts **Oversized ports with flared ends for efficient air flow and no noise **3/4" MDF Construction **Heavy duty black carpet covering **Embroidered Kicker logo **Dimensions: 32-3/8" W x 16" H x 17-3/8" D (Bottom) x 13-15/16" D (Top)
Is the amp supposed to be 1,2,4, or 5 channel wattage and what has to match the sub.
i dont know much at all
a small one that does about 400-500wrms at 4ohm or 1ohm
which one of these is right
**Features: **MAX POWER, 2 OHM: 1100w x 1 **RMS POWER, 4 OHM: 250w x 1 **SIGNAL-TO-NOISE RATIO: > 105 dB **THD: 0.01% **DIMENSIONS: 11-7/8"W x 2-5/8"H x 10-9/16"L **Remote subwoofer level control ** Line and speaker level inputs **Variable gain control **Variable lowpass crossover **Power and protection LEDs **0-+18dB selectable bass boost **MOSFET power supply
or
**Features: **MAX POWER, 2 OHM: 300w x 2 **RMS POWER, 4 OHM: 110w x 2 **MAX BRIDGED POWER, 4 OHM: 600w x 1 **SIGNAL-TO-NOISE RATIO: 102 dB **THD: 0.01% **DIMENSIONS: 11-7/8"W x 2-5/8"H x 10-9/16"L **Trimode operation **Bridgeable **Remote subwoofer level control **Line and speaker level inputs **Variable gain control **Power and protection LEDs **Variable lowpass crossover **High pass crossover **0-+18dB variable bass boost **MOSFET power supply
or
**PowerZone Amplifiers Feature: **SEPP A/B-Class P-Series Amplifier Designs **Bridgeable Designs: All 2-Ch & 4-Ch **Illuminated, Large New Design Crunch Logo **P. MOSFET Pulse Wave Modulated Power **Supply For Instant Maxx Current Output **1-Ohm Capable A/B Class Mono Block Amps **2-Ohm Capable A/B Class 2/4/5-Ch Amps **4-Ch Amps Config to 3-Ch R & L and Sub Mode **Rugged MOSFET Audio Outputs **P-Series Amp Protection with System **Diagnostics LED's That Protects Against: **Current / Amperage Overload **Short Circuits **Thermal Overload **DC Offset **2/4Ch Amps Have Hi-Level Speaker Lead Inputs **Silver Preamp Level RCA Inputs **Daisy Chain Line Outputs (except P-Series 5000.5) **Mono Blocks & 5-Channel P-Series Amp **Include a Remote Bass Control **Versa Cross™ Sound Shaping Controls* **Mono/Stereo Switch **HP/LP/Full-Pass Freq. Selections **Crossover Frequency Adjustments: (60 Hz to 1.2kHz for all multi-Ch amps) (30 Hz to 250 Hz Low-Pass*) *Exception: P 1000.1 & P 1500.1 are Low-Pass Only **Adjustable (60Hz to 150Hz) & Include Variable Subsonic **Filter (15Hz to 55Hz) **4-Ch P-Series Include Separate F & R Bass EQ Controls Adjustable +12dB Bass EQ @ 45Hz **Input Level Control (0.2 to 5V for all 2/4/5-Ch Amps or 6V for P Mono-Block Amps) **Oversized Speaker Terminals **"Powered By Maxxsonics" Technology **P 900.4 **900W 2 / 3 / 4-Channel A/B Class Amplifier **115W x 4-Ch @ 4-Ohms or **225W x 4-Ch @ 2-Ohms or **450W x 2-Ch @ 4-Ohms Dynamic Music Watts
krj725
krj725
Boston
krj725
