big amp vs. bigger amp
Jep772
ok i got a decision to make TODAY, local shop has rockford t2k in my price range, which is about the same price as the saz-3000d that i originally intended to buy.
i know the sundown is more powerfull and a few bucks cheaper but requires 300a's external fusing and would be more of a drain on my electrical... the punch has built in fusing and draws less current so would be a little safer on my:
single run 1/0, small stinger battery in the trunk and 1/0 big 3, 105a alternator.
which would you do? the sub is a 9515f btw.
yea i bet with a 16v line driver on that rockford it'd really beat the shit out of my 15" and be a lot less of a drain on my sorry electrical. thanks for the input i think im gonna go drop some bread on this RF
the sundown will make its power @12 volts and around 4k @.5ohm and 14.5 volts.both good amps though,the rf is prolly better for your setup
I would get the 3000D and have that little bit of extra power when you need it for burps //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
You can always mess with the settings so it isnt always draining a ton of juice //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Jep772
Jep772
Indianapolis, IN.
xclusiv3
