I only ask because I know people like to do these with 0 Ga. but mostly people who do it have more power needs than I do. I mean, the amps i'm powering only have a 4 Ga. cable, why would I need more than that at the other end of the circuit?
The thing is I'm sorta tapped out right now at least for a few weeks and I've already got the 4Ga. so I could be working on it.
I'm only pushing a 350 watt amp and a 320 watt amp (conservative RMS, these amps are under-rated), so figure 700 watts max, maybe potential for a bit more..
A bonus question for those who survived round one of my long-windedness is -
Although I'm feeding both amps with a single 4Ga. at the moment I plan to do phase two which is feeding them with a batt that is 12 inches away. Then I plan to use the 4Ga. Power line as a charging lead from the alt. once again, is 4 ga. enough to charge the batt. efficiently when I'm driving, about a 10 foot run to the cargo. My listening habits will probably have me at 1/3 of the volume 90% of the time so the bat will be mostly charging more than draining except when I use it with the car off.
