a yes first off i plann on doin the big 3 but i was wondering about the wire, i was wonderin is power wire considered as both the positive and the ground wire, cause i found a roll on ebay of power wire in 25 ft, i was wonderin if i can use it as both the positive wire and the ground wire, or do i have to have 2 specific wires? also im going to run a 4 channel amp to my componet speakers, now is the way a mids and highs amp works is you just run a rca signal to the amp from the HU and run the speaker wire from the amp to each speaker, or do i have to use the hu factory speaker wires from the harness, or do you just cancel them out unless using the HU amp?
