big 3 ? voltage meter ****in crazy
blackman
teh NEGROS
alright I did the big 3 in my 88 chevy g20 and now the voltage meters rapidly jumps back and forth between 14 and 15 volts maybe 16 volts. why does this happen after I pass 15 mph Ive never seen this before? btw before i pass 15mph im sittin at like 14.6-14.8 volts
Your '88 is a bit old but I know in my '08 I have a voltage regulator loop that the ground wire from the battery runs through so the onboard computer can monitor and regulate the voltage...do you have anything like that? Maybe you bypassed it? Just a thought.
if it goes from 14 to 15 then i would guess at the speed you where going the alt was charging between 14.9 and 15.1 and just bouncing between the two.. that I would say is normal. 16 volts although is not normal unless you have a 16 volt setup, perhaps your voltage regulator is failing?
blackman
teh NEGROS
blackman
oklahoma
Compjake
