Best Glue For Wood
I tested the stength of some wood glues and the Loctite Wood Worx glue was the best, much stronger than the titebond II i used, although with both the wood broke before the joint so it doesnt really matter
the Wood Worx is a little thicker and easier to work with than the titebond stuff....
If the wood broke before the joint on both of them how can you say the glue is stronger? At this point you would be saying the wood on the Worx glue was stronger than the wood on the titebond test sample.
Because when i tested it, i used less and less glue until i was able to notice a difference in the two.
titebond 3don't use gorilla glue. it expands when used
i use titebond as well, however, i have used gorilla glue in the past for boxes and the sh!t is strong as hell. very ugly, but strong. works great if you're gluing 2 different materials together, such as plexi to wood or metal to wood.
dont use anything other than a dedicated WOOD GLUE for bonding WOOD to WOOD.
dont use construction adhesive or liquid nails or any of that crap. wood glue has been proven to be stronger. period.
MasterOfAllBass
Team Minnesota's Loudest
MasterOfAllBass
Minnesota
PV Audio
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
