Best Amp
kayzee
14
ny
I bought 2 Alpine Type-X subwoofers. Featuring 3000W(Peak)/1000W(RMS) Power Handling, Frequency Response of 23Hz – 200Hz, and VC Connection Jumper System.
I need to know what is the ideal amp for these 2. And if there is any other impotant information i should know
whats the coil configuration on them? dual 4 ohm each?
1000W RMS/3000W Peak Power Handling
Frequency Response: 23Hz – 200Hz
Carbon Fiber/Aluminum Honeycomb/Kevlar Reinforced Pulp Cone Woofer
Ultra High Excursion Multi-Roll Injection Moulded Santoprene® Surround
Mirrored Progressive with Perimeter Venting
Compound Radius Curve
Nomex Spider
Extended Dual Flare Pole Vent
3" Voice Coil
8.6" Top Mounting Depth
Copper Shorting Sleeves with Thermal Coupling Plate
kayzee
kayzee
ny
kayzee
