turnitdown
I can get either a Opti 1000.1d Competion Amp
http://www.lanzar.com/itempage.asp?MODEL=OPTI1000.1D
1000 Watts x 1 @ 1 Ohm
Class ''D'' Design
Extremely Fast Switching Power Circuits
Super High Current Output Stages Using
Multiple High Current MOSFET's
Independent 24 dB Per Octave
Hi & Low Pass
Wired Bass Jack
Adjustable Gain Control
Variable Bass Control
4 Inputs Mixed to Mono For
Front/Rear Fading
1 Line Level Output For Brodging
2 OptiDrive Class ''D'' Amps Together
Variable Phase Shift
Variable Base Boost
or
OPTI1400D
# Mono Block Subwoofer Amplifier
# 1 Ohm Stable
# MOSFET Power Supply
# PWM (Pulse-Width-Modulated) System
# Double Sided Epoxy PCB Circuit Board
# Gold Plated RCA Inputs
# Custom Terminal Block for Speaker Connections
# Thermal, Overload & Short Protection
# Remote Bass Control
# Soft Turn On/Off
# 500 Watts RMS Power into 4 Ohms
# 800 Watts RMS Power into 2 Ohms
# 1000 Watts RMS Power into 1.3 Ohms
# 1300 Watts Max Power into 1.3 Ohms
# THD @ 1Watt/4 Ohm: 0.1%
# S/N Ratio: 90dB
# Frequency Response: 15Hz - 150Hz (+/-3dB)
# Damping Factor @ 20Hz/4 Ohms: 400
# Variable Low Pass Filter: 50Hz-150Hz, 24dB/Octave
# Variable Subsonic Filter: 15Hz-40Hz, 24dB/Octave
# Variable Bass Boost: 0 to +18dB
# Phase Shift Control: 0 to 180
# Input Sensitivity: 200mV ~ 8V
# Input Impedance: 10k Ohm
# Line Output Impedance: 100 Ohm
# Fuse Rating: 30A x 4
# Dimensions: 10.08'' (W) x 2.12'' (H) x 14.96'' (L)
I can get either one for the same price, and I'm going to buy 2 and strap them which one would be better?
Class ''D'' Design
Hi & Low Pass
Wired Bass Jack
Front/Rear Fading
Variable Base Boost
or
OPTI1400D
# 1 Ohm Stable
# Soft Turn On/Off
# S/N Ratio: 90dB
