Sold BatteryCorp 12V170FT HUGE BATTERY, Like a Northstar NSB170
TeamPSI
Super Pimp VIP Member
https://www.batterycorp.com/DOCS/12V170FT.pdf
Nominal Voltage 12 volts (6 cells)
Nominal Capacity
20 hour rate 190 AH (9.048A to 1.75 Vpc)
8 hour rate 171 AH (21.3A to 1.75 Vpc)
Dimensions
Length 21.97 in (558 mm)
Length Base 20.87 in (530 mm)
Width 4.92 in (125 mm)
Height 12.20 in (310 mm)
Weight 133 lbs (60 kg) Maximum
Terminal
Torque Value 100 in-lbs (11.3 Nm)
Type Copper Alloy Insert – M6-F
Stud –M5-M / 50 in-lbs (5.6Nm)
Internal Resistance 3.22 mΩ
Maximum Discharge Current
Continuous 500 amperes
Short Duration (
Operating Temperature Range
Charge -20ºF (-28ºC) to +122ºF (50ºC)
(with temp. V compensation)
Discharge -40ºF (-40ºC) to +122ºF (50ºC)
Nominal/Recommended +68ºF (20ºC) to + 77ºF (25ºC)
Storage -4ºF (-20ºC) to +104ºF (40ºC)
Charge Voltage
Float 13.4 to 13.6, constant at 77ºF (25ºC)Cycle 14.1 to 14.7, constant at 77ºF (25ºC)
Maximum Charge Current 42 amperes - C/4 amperes
Short Circuit Current 3881 amperes
These are BADASS! One of these is roughly equivalent to 2 Group31 batteries or more.
$300+ship, brand new
TeamPSI
TeamPSI
Pink Star Industries
TeamPSI
