Batt Question need answer please
Petey Goldz
so im planning on throwing the AQ HDC3 - 15 on the 2200D in my 91 LeSabre, and i was wondering if i get the big 3 done can i just run a huge battery under the hood? if not what would you suggest.... btw the current Alt is 105amp and its a daily driver
- Pat
good car to work with....i have a 90 LeSabre custom. if you need any advice on where to run wires, how to get shit apart, etc, let me know. The Big 3 helped me a lot, and i just have a duralast battery. But I also am not running that much power either. I would try that and then a bigger alt, and a 2nd batt would be my last option
thanks map, ill prolly be needing ur help in the near near future.....i was really thinking of getting a EA 200amp alt, if i did that would i still need 2 batterys if so what would you reccomend, currently have a Diehard Gold under the hood.
The order I would upgrade things is the following:
Big 3--a must, no option there
Good front battery--get a deep cycle battery, best you can afford
New Alternator
2nd battery
upgrade your electrical in that order until you're fine. You may not need that 2nd battery, in fact I doubt you will iff you have a strong alt and a good front battery.
New Alternator
2nd battery
ok thx!!!//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Petey Goldz
Petey Goldz
MICHIGAN
Petey Goldz
