bass isnt kicking in on time
Xdmethod24
i just wired my friends system and as far as i know i did everything right but clearly not. when i turn my volume down past a certain level the bass cuts out and then when i turn it up the bass takes about a minute to start working? is that like rca lag? how do i fix it?
sounds like your electrical can't handle the amp. What are you running for amp and wiring? Have you done the big 3?
no i didnt do the big three cause i dont know where the alternator is or how i would attach a wire to the engine block. plus the pictures on the thread are gone.
either way i also didnt do it cause i dont think its a serious enough sound system, his speakers are running off the head unit we only have one amp in the back and i think its only a 250 watt amp hooked up to one 12 in sub? the power wire ran is eight g
it doesnt seem like a power issue to me cause it works fine after it kicks it and wont cut out or anything it just takes a second to start working?
Xdmethod24
Xdmethod24
Boston
ultimate157
