1. Product: avionixx AXA.440.4
2. Specs:Class A/B amplifier
MAX Power @ 4ohm 2x440 Watts Bridged
RMS Power @ 4ohm,
RMS Power @ Bridged 4 ohm
RMS Power @ 2 ohm,
Power Bandwidth (Rated Power -1dB) 15Hz - 30kHz
Frequency Response (+0/-3dB) 5Hz - 70kHz
"A" Weighted Signal to Niose Ratio >-90dBA
Channel Seperation >60dBA
Damping Factor >200
Variable Input Level 150mV - 6V
Variable Frequency Bass EQ 25Hz - 80Hz
Controlled Electronic Noise Suppression "Cens" Yes
Variable Low Pass Crossover Filter 50Hz - 250Hz 12dB
Variable High Pass Crossover Filter 50Hz - 250Hz 12dB
Double Sided, 1Oz. Copper Clad FR4 board Yes
Overload Protection Yes
Short Circut Protection Yes
DC Off-Set Protection Yes
Thermal Protection Yes
Fuse 2 x 40A
Heat Sink Dimensions - Inches 13 7/8x 9 7/8 x 2 1/4
Heat Sink Dimensions - Millimeters 352 x 251 x 57
Weight 12 Lbs.
3. Description/Condition: Amp is used and has a few scratches but nothing bad this is a really nice amp that does some good power and sounds very clean This amp is very underrated and was rated at 12 volts
4. Price: :100 plus shipping if I cant get this I will just keep it this amp is alot better then most of the crap out these days.
5. Pictures:
RMS Power @ 4ohm,
RMS Power @ 2 ohm,
Damping Factor >200
Fuse 2 x 40A
Weight 12 Lbs.
5. Pictures:
