NIB AVI LXD-160 $115pr shipped
MODEL AVI LXD-160, 160 mm (6.5") MIDBASS DEVICE
APPLICATIONS
This is a midbass device for very high performance sound systems.
Suggested operating range is 48 Hz to 5 KHz.
PERFORMANCE
48 Hz at -10 dB points, in the optimum vented enclosure without crossover.
73 Hz at -3 dB points, in the optimum vented enclosure without crossover.
150 watts music program material.
100 watts AES pink noise rating.
89 dB average, at 1 watt and 1 meter, in half space.
4 ohm nominal, 3.3 ohm minimum.
FEATURES Black aluminum frame with cavity vents.
Extended and vented pole piece with integrated bottom plate.
Both top and bottom plates with CNC and black absorbing finish.
Black PP Mica cone with composite rubber edge.
798 g (28.1oz) magnet.
50 mm (2") aluminum ribbon voice coil.
PHYSICAL 157 X 157 mm (6.1" X 6.1") overall size.
70 mm (2.76") overall depth without grille.
141 mm (5.55") cut out hole diameter.
65 mm (2.6") mounting depth without grille.
63 mm (2.5") mounting depth with grille.
2.23 Kg (4.01 lbs) weight.
T/S DATA
Znom 4 Ohms Revc 3.3 Ohms Fo 41 Hz
Sd 0.0117 M2 (18.0 in2) Le 0.128 mH SPL 89 dB
Xmax 5.5 mm (0.22 in) Qms 5.570 BL 6.9 TM
Vas 22.24 L (0.785 ft3) Qes 0.297 Pnom 100 W
Cms 941 µm/N Qts 0.282 Pmax 150 W
Aura NSF8 pr $125pr shipped These make a great midbass speaker also. These are the same speaker McIntosh uses in the ford GT400
Aurasound NSF8-495-4A 8" Shallow Profile Woofer 4 ohm Woofers ~8"
Quantity:
Madisound# NSF8-495-4A
Aurasound 8" Shallow Profile Woofer - 4 ohm
Features:
* Shallow depth
* Good for autosound or in-wall
* Underhung voice coil
* NRT neodymium magnet system
* Inherently shielded
* Low bass in a small enclosure
Specifications:
Fs 35 Hz
Nominal Imp. 4 ohms
Power (RMS) 100 W
Re 2.65 ohms
Sens. 1W/1m 84 dB (2.83V@1m = 88.8dB)
X-max peak 3.5 mm
Qms 4.83
Qes 0.28
Qts 0.26
Vas 17.1 ltrs
BL 11.7 TM
Mms 64.2 gr
Cms 316 mM/N
Sd 196 cm2
VC diameter 50 mm
Recommended Enclosure:
F3 of 50Hz in 0.35 cubic foot with a 2" diameter vent by 7" long.
APPLICATIONS
PERFORMANCE
T/S DATA
Quantity:
Features:
* Shallow depth
Specifications:
Fs 35 Hz
Nominal Imp. 4 ohms
Power (RMS) 100 W
Re 2.65 ohms
X-max peak 3.5 mm
Qms 4.83
Qes 0.28
Qts 0.26
Vas 17.1 ltrs
BL 11.7 TM
Mms 64.2 gr
Cms 316 mM/N
Sd 196 cm2
VC diameter 50 mm
