Avalanche hair trick!
whoa guys. calm down. I could care less about the comments about pete as immature as they may be, but i dont see the need for 10 guys to bash tuan for stickin up for his friend.
everyone should just be grateful for the vid //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
just guess and play alot of notes. id imagine the ones that move the cones the furthest... prolly closest to tuning freq is where id start... but dont bottom them out //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
and roll all the windows down cept the one the hair is at, and sit her right there //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
now jelly - get some **** vids already!
well @ tuning is when the cone moves the LEAST...but the pressure inside the box is the highest. do you know what that box is tuned at? (TUAN'S BOX) he said it was an SQL car so i'd assume right around 30. i played with it the other day with the paper, and the paper moved the most around 20Hz. the penny vid kinda sucks! my roof is so small that it really doesn't flex much...which isn't really a bad thing;) and lastly i gotta wait till tommorow to get the hair vid when i go to my moms. my g/f has kinda short hair and it doesn't get going as good as my moms.
but nowhere near as good as tuan's.
i was gonna try to get that vid today, but my starter went out this morning, and since i didn't write down all my settings (like the book said to:() i wanna break out the DMM and reset my gains before i go burping 20Hz tones, if you know what i mean.....
well @ tuning is when the cone moves the LEAST...but the pressure inside the box is the highest. do you know what that box is tuned at? (TUAN'S BOX) he said it was an SQL car so i'd assume right around 30. i played with it the other day with the paper, and the paper moved the most around 20Hz. the penny vid kinda sucks! my roof is so small that it really doesn't flex much...which isn't really a bad thing;) and lastly i gotta wait till tommorow to get the hair vid when i go to my moms. my g/f has kinda short hair and it doesn't get going as good as my moms.but nowhere near as good as tuan's.
that box is actually not just a straight up ported box. Its a pretty complicated design. I think its kind of a mix of a horn and a tl. I really have no idea. All I know is it is **** loud and sounds good too.
hair trick vid with your mom. that's just wrong man. :p but don't forget to play 33 hz //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I can do a hair trickI just use my air compressor //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
prove it //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
you wanting me to play 33Hz with my mom is wrong //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif but her hair is about as long as the chick in the vid, and everyone else i know has like shoulder length hair. and besides...my mom is good people, you be nice //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I know that a low tuning(i.e. 30Hz and below) with a lot of port area can get some hair moving, then factor in your power, try burping yours @ 30Hz and see what happens, mid to high volume too. But like said above, Pete's wall is a hybrid TL/rear horn with hella port area tuned @ 30Hz.
just playin with you //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Let us know how it goes and make a vid if you can (and are willing to solicit your mother like that //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif )
well, i'm tuned @25Hz w/ 70 in^2(i wish i could of got more:() and 1500w. so for this vid, all the windows up, except hers, should she be in the car w/ her hair hanging out? i've only done it with her outside the car, putting her head up to the halfway rolled down window.
also does anyone know where i can learn more about that type of box? is it pretty hard? it's huge aint it?
Well, his is a hybrid - hence, he degined it;)
But, these may help you understand them. - http://www.t-linespeakers.org/
TL calculator - http://fermi.la.asu.edu/w9cf/tran/
horns - read all of the links on the left http://melhuish.org/audio/DIYRH1.html
Aslo make sure to round out all ot the angles in your box, no 90degrees.
phildapimp89
phildapimp89
IL
JoseMCeee
