AUX CONNECTOR INSTALLATION FORD 6000CD
  • 2
zayfoy
Hey,
I own a 6000CD radio unit which has an AUX button but no visible input connector.
I recently purchased an AUX adapter cable that's to be fitted to the rear of the radio unit but during installation, after I had unmounted the radio unit, I realised that there is a pre-existing connector (images attached to the post) that's in the targeted location. Would this be because the wiring for AUX usage is already installed and the output is located elsewhere? If not, how would I go about installing an AUX adapter cable?
I've seen several videos of individuals accessing the rear of the glove compartment to find the ends (which I've not yet done) so I'm guessing this should be my next try.
Any help would be appreciated guys!
Thanks
I would wholeheartedly recommend saving up for an actual head unit with aux, bluetooth etc... they are only 100ish bucks and comes with free dash kit and wiring harness if you buy from crutchfield. Your sound quality, loudness and overall user experience will be a lot better than a junky stock head unit.
From what i see you have to remove the glove compartment and there's a connector inside there. However the sound is fairly bad with aux so its not really an upgrade for anything, a lot of degredation with aux and stock head unit.
There is the 16pin connector in armrest of my old mercedes 2006 S350. Any possible way I can stream music from my phone wirelessly(Bluetooth) or...
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
you did. https://www.caraudio.com/threads/double-din-cd-player-with-screen-mirroring-a-link-android-auto-budget.614240/#post-8864499 OP:
They are. But, after using sort of them, i think best way is to root phone and do some real system modifications with Viper.
zayfoy
zayfoy
Jeffdachef
    May 18, 2024
    May 18, 2024
