Deadbeat
Anyone know anything about this alarm?
I was quoted 500.00 w/ installation. Does that sound decent?
* STANDARD FEATURES
- One, 8 button High Frequency Standard Remote Transmitters
- One, 8 button 2-way LCD transceiver
- Two-way, window mount extended range helical transceiver antenna module
- SIS-11 dual stage shock / glass sensor
- Discrete temperature sensor that communicates in-car temperature via LCD remote
- Window mount knock sensor for driver paging
- Remote car starter with 5 on-board relays and all the features of the RS-650
- 66 Bit Random Code Hopping
- Code Learning / Anti-scan Receiver
- Back-up Memory System
- Dedicated Remote Panic and Car Locator
- Passive Arming By-pass from Remote
- Parking Light Flash Dual Polarity (relay on-board)
- 2nd Channel Auxiliary Output
- Plug-in Push type Valet/Override Switch
- Plug-in Super Bright LED
- Starter Disable Output with Relay & Socket (included)
- Dome Light Illuminated Entry
- 1 Positive, 4 Negative Inputs
- Error By-pass Reporting
- 120 db Electronic siren
- Horn Honk Output
- Ground When Armed Output
- Dual Polarity (+/-) Door Lock Outputs
- Drivers Priority 2 Step Unlock
- Output for optional P.I.R. sensor
- All Programmable Features are Programmed via the Remote Transmitter
TWO-WAY LCD REMOTE OPERATION
- Two-way transmitting remote and paging receiver with 3 color LCD-
- Transmitting range up to 1000 feet and receiving range up to 1 quarter mile
- 8-button configuration (3 buttons on front & 5 buttons on side)
- Powered by 1 "AAA" type 1.5volt alkaline battery with battery life indicator
- 3-color LCD screen displays
- Over 25 icons and figures providing around the clock confirmation on vehicle and alarm status
- Back lighting for nighttime use
- 24 hour digital clock with countdown timer for parking meter reminder and alarm
- The clocks doubles as a temperature indicator for monitoring in-car temperature
- Multiple audible confirmation tones and melody chimes as well as vibrator mode for paging
- Silent arm mode capable
REMOTE START FEATURES
- 5 On Board Relays
- Ignition 1, Ignition 2, Starter, Accessory, Parking Light, 3rd Ignition Output, Ground When Start Output
- Diesel Fuel Compatible
- Hood Safety Pin Switch Input
- Selectable Voltage / RPM Start Sensing / Timer Start
- Timer Start Control (.6 seconds - 4 seconds)
- Temporary Stop Feature
- Factory Security Disarm & Rearm outputs
- Programmable 3 Hour / 24 Hour Timer Start
- Sensor Control Output During Start
- OEM Alarm Output
- Selectable Run Timer
- Ignition Control Lock By-pass During Remote Start
PROGRAMMABLE FEATURES
- Chirp Delete
- Manual / Passive Arming
- Passive Arming Door Locks
- Ignition Control Door Locks
- Automatic Re-arm
- Single/Double Pulse Unlock
- Pathway Illumination
- Voltage Sense/RPM Sense/Timer Start
- 5,10,20,30 Minute Run Timer
- Gasoline/Diesel Engine type
- Lock-Unlock Output Timing (.9-3 sec.)
- Factory Disarm/Rearm
* STANDARD FEATURES
- Horn Honk Output
- 5 On Board Relays
- OEM Alarm Output
- Chirp Delete
- Automatic Re-arm
