Aura Stage2 2150 amp
  • Thread starter Jam1e
  • Replies 0
  • Views 489
Jam1e
Aura Stage 2 2150 2 channel amp.
Had this amp for 2 years. works great. 8/10 cosmetically. 10/10 performance
•Power output: 2 x 110 watts into 2 ohms, 2 x 75 watts into 4 ohms, 1 x 225 watts bridged mono into 4 ohms •Total harmonic distortion: 0.5% THD, 20 Hz to 20 kHz at rated output •Signal to noise ratio (S/N): > 85 dB •Input sensitivity: 150 mV~ 5 V (low level), 1.5 V to 25 V (high level) •Frequency response: 20-20,000 Hz •Dimensions: 9-1/8" W x 2-1/4" H x 9-3/16" L.
Additional features: •Variable remote bass level control 0 to +10 •Variable level controls •Variable 18 dB per octave low-pass crossovers (50-250 Hz) •Variable 18 dB per octave high-pass crossovers (50-250 Hz) •Switchable 10 dB bass boost at 55 Hz •Preamp outputs provide system design flexibility •High level inputs for OEM integration •Large 8 AWG compression terminals for system connection •Power/protect LED indicator.
100 shipped
Jam1e
Jam1e
Green Bay
Jam1e
