Item(s) for Sale: AuraSound NS3-193-8A 3" Extended Range Driver 8 Ohm
Item(s) Description/Condition: Aluminum cone, high roll surround, neo motor. These things bump, ran with no x-over and was shocked at the sound they produced. Unreal truly excellent sound reproduction, really surprised me.
Creating modern high fidelity, low distortion speakers is easy with AuraSound's revolutionary NS3-193-8A 3" full range woofer. The self-shielded, radially polarized Neo-Radial Technology (NRT) motor focuses over 95% of the magnet's energy onto the underhung voice coil, forcing the cone to follow the input signal, reducing distortion.
For longevity, the NS3 is built using an aluminum cone that's mated to the stamped steel frame with a rubber surround. The Kapton® former and copper-clad aluminum wire (CCAW) voice coil help to increase peak power capacity. 9.5 mm of peak-to-peak excursion allows you to use this driver at, and below, the 80 Hz resonant frequency with authority without affecting its top-end response.
Product Specifications
Nominal Diameter3"
Power Handling (RMS)20 Watts
Power Handling (max)80 Watts
Impedance8 ohms
Frequency Response80 to 15,000 Hz
Sensitivity80 dB 1W/1m
Voice Coil Diameter0.76"
Thiele-Small Parameters
Resonant Frequency (Fs)80 Hz
DC Resistance (Re)7.6 ohms
Voice Coil Inductance (Le)1.1 mH
Mechanical Q (Qms)8.0
Electromagnetic Q (Qes)0.73
Total Q (Qts)0.67
Compliance Equivalent Volume (Vas)0.04 ft.³
BL Product (BL)4.7 Tm
Diaphragm Mass Inc. Airload (Mms)4.3g
Maximum Linear Excursion (Xmax)4.25 mm
Surface Area of Cone (Sd)31 cm²
Materials of Construction
Cone MaterialAluminum
Surround MaterialRubber
Voice Coil Wire MaterialCCA
Voice Coil FormerKapton® / Polyimide
Basket / Frame MaterialSteel
Magnet MaterialNeodymium
Mounting Information
Overall Outside Diameter4.07" diagonally, 3.48"
Baffle Cutout Diameter2.97"
Depth2.16"
Bolt Circle Diameter3.66"
# Mounting Holes4
Optimum Cabinet Size (determined using BassBox 6 Pro High Fidelity suggestion)
Sealed Volume0.10 ft.³
Sealed F395 Hz
Vented Volume0.12 ft.³
Price: $40
$7 conus
Nominal Diameter3"
Impedance8 ohms
Total Q (Qts)0.67
Depth2.16"
# Mounting Holes4
Sealed F395 Hz
Price: $40
$7 conus
