Audison LRX 150.2
  • 2
grunge
Audison LRX150.2 amp
This is an earlier gen lrx amp than the others I have. This gen is the one that turned me on to audison.
I was never able to cram this amp in my install so I has also never been used by me.
https://www.manualslib.com/manual/753936/Audison-Lrx2-150.html?page=2#manual
Distortion – THD (1kHz): . . . . . . . . . . . . . . . 0.009 %
Bandwidth (-3dB): . . . . . . . . . . . . . . . . 4 Hz ÷ 85 kHz
S/N ratio (A weighed @ 1V): . . . . . . . . . . . . . 105 dB
Damping factor (1 kHz, 4 Ohms): . . . . . . . . . . . 240
Input sensitivity: . . . . . . . . . . . . . . . . . 0.2 ÷ 5 VRMS
Input impedance:. . . . . . . . . . . . . . . . . . . . 15kOhms
Load impedance:
- 2 Ch. stereo: . . . . . . . . . . . . . . . . . . . . . . . . 4-2 Ohms
- 1 Ch. mono in bridge: . . . . . . . . . . . . . . . . 4 Ohms
Nominal output power (RMS)
NP @ 12VDC; THD 0.3%: . . . . . . 70W x 2 (4 Ohms)
Output power (RMS) @ 13.8 VDC;THD 1%
- A config.: . . . . . . . . . . . . . . . . . . . 80W x 2 (4 Ohms)
- B config.: . . . . . . . . . . . . . . . . . . 110W x 2 (2 Ohms)
- C config.: . . . . . . . . . . . . . . . . . . 220W x 1 (4 Ohms)
$150
You pay actual shipping.
I also have the newer LRx 3.1k, LRx 2.4, and LRx 6.9 for sale in this section, and an Audison BitOne for sale in the other section. Will combine shipping and deal for buying more than one item.
Anything worth getting is always worth it more at a steep discount. Not familiar with that unit, but the brand is great.
I would pull the amp and bench test it with power and ground wires. If it still doesn't power up, its probably shot. My next step would be to...
Yes mate I have these in a 3 way active front stage and they sound great, have them crossed at 5k, see my recent post for full breakdown of kit I...
If the plug matches, you just need to match the wires up. I re-made the harness for my audison amp, and the hardest part was getting the speaker...
grunge
grunge
Rochester, MN
Dub7sonoma
    Apr 28, 2024
    Apr 28, 2024
