Audioque HDC312 voice coil config?
Echo42987
Well I think I've narrowed it down to
2 12" HDC3's and a Audioque 2200D
but I was wondering what Voice Coil config should I get. I want to run it at 1 ohm? Should I get the D1's or D2's? As far as I know I can only wire two D2's to either .5ohms or 2 ohms. What are the wiring configs for D1's?
-Nick-
Personally I'd do a 2200D per sub, but they should get pretty loud off a single amp.
What you doing for box size/tuning? I'd do it a little on the big side since you're not throwing that much power at them...
Um I don't know yet. Haven't gotten that far. What would be recomended?
I thought they only need 1000rms each?
-Nick-
I run 2k to each of my HD's daily with no problems.
I prefer a 35Hz tune as I mostly listen to rock, but 38-40Hz is fine if you mostly listen to rap. I'd do around 4.25-4.50 cubes...
Echo42987
Echo42987
Antioch, IL
Echo42987
slater
    Oct 4, 2025
    Oct 4, 2025
