LPF should be set between 75 and 100. Lower than 75 and you are cutting out a lot of mid bass.
Multimeter is absolutely needed.
50hz -3db sin wave on cd
Follow these steps:
1.
Check how many volts your amp is putting out by playing the 50hz sin wave at listening volume with the multimeter.
watts = volts^2 / ohm - this is not the actual equation for it (real one involves a lot more variables) but it is a general rule to follow.
2.
Now check how many volts its putting out inbetween 0 and listening volume, so about half way.
3. Check your RCA volts from the deck by unplugging them from the amp and setting your DMM to AC~ touch the neg to the ground on the amp and the pos to the tip of the rca, do this at listening volume with the 50hz tone.
Things to never do:
Never use bass boost on amp, adds tons of distortion.
Never turn the bass or sub level all the way up on the deck, it adds tons of distortion. Keep everything FLAT.
Never play 0db bass songs if amp tuned with -3db sin wave, you will clip the hell out of your amp and possibly blow the sub.
So i've given you all the tools needed, figure out whats wrong with her.
