Audioque AQ750
area51
Audioque AQ750
Used but in outstanding condition. Only blemish is tiny scratches on the mounting tabs.
Model AQ750D
Frequency Response 20Hz—250Hz
Signal to Noise Ratio 100db
Low Pass Crossover 24db / Oct
Low Pass Crossover Range 20Hz—200Hz
Subsonic Crossover Range 10Hz—50Hz
Input Sensitivity 0.2V—8V
Output Master / Input Slave Connection Yes
Working Voltage 8V---16V
Efficiency @ 4 ohm 84%
Damping Factor Less than 150
Fuse Rating 30Amp X 3 (Linked 180 Amp)
Output Power 14.4V @ 1% THD 300X1 @ 4 ohm,500X1 @ 2 ohm,750X1 @1 ohm
Output Power 14.4V @ 5% THD 1000X1 @ 1 ohm
Dash Mounted Remote Included
Dimensions 10.00"(L)x9.27"(W)x2.35"(H)
$175.00 Shipped
area51
area51
Honolulu, HI
area51
