Audioque AQ 2200D vs Hifonics BXi2608D vs Audiopipe 3000D
dude an ap3k will rek all these amps the ap3k actually does 3000. i have the amp its awsome sounds clean puts out a shit load of watts! i love it i would go with ap imo!!
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif thats a good review!
i have to agree, the ap3k will actually do 3k, however its rated for 3k at 2ohms, where the other 2 are rated at 1ohm... so depends on your setup as well
well actually if u have a dual 1 ohm sub u can run it like this and do the same one coil to 1500rms wihch is one amp and the other coil 1500rms which is other amp. two amps in one ap3k so it doesnt matter really dual 1 ohm subwoofer on that amp can work it two diff phases. if u dont get what im saying just pm me its like eiser toi explain there
ap3k as in audio pipe 3000d?
Audiopipe=most powerAudioque=Best quality and C/S
Hifonics=Might be cheaper
thats a pretty good comparison, i like it
Its still not going to be running at 1 ohm
Yes, you are correct, running each coil separately to each channel will be 1ohm each making it a 2ohm load.....I would NOT run the amp at a .5ohm...it's basically two 15001D's strapped...if running the sub at .5 that's running each 1500 at .25...this amp is protect happy at 1 ohm so unless you have very good electrical i wouldn't even run it at 1ohm...but since your sub is dual 1 then the AP30001d would be perfect at 2 ohm. which i believe the rating should be 3k@2ohm. there are also their new amps like their 2.5k and 3.5k models which i have read that the 35001 will run at 1 and .5 daily and .25 burps:
AudioPipe AQX25001~~~$400 shipped
http://cgi.ebay.com/AudioPipe-AQX-2500-1-2500W-D-Class-Amp-Mono-AQX25001_W0QQitemZ260474048693QQcmdZViewItemQQptZCar_Amplifiers?hash=item3ca57690b5
AQX35001~~~$450 shipped ($50 more for 1k more)
http://cgi.ebay.com/AudioPipe-AQX-3500-1-3500W-D-Class-Amp-Mono-AQX35001_W0QQitemZ260474047676QQcmdZViewItemQQptZCar_Amplifiers?hash=item3ca5768cbc
Kryptonitewhite
Kryptonitewhite
soo foo sd
dadydolas
