Audiopulse Revo 15"
Almost $500 for a TC9 based driver is not a great price just because TC recently raised prices arbitrarily. That speaker offers no more performance than other TC9 models did just a few months ago, that cost considerably less. Not dissing th speakers, or the decision to buy them... but I'll be **** if I'll agree that price is 'good' just because of TC's price adjustments. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Beautiful subs, hope they work out well for you man.
Actually they do indeed offer more performance than other TC9 based drivers from a couple months ago. Just Compare the T/S. They also carry a life time warranty.
I believe it's actually the motor they used on the OEM drivers. Basically a triple stacked TC9. I think those are 195 oz while the oem was 185.
My friend jake just put to of the REVO 12s in his lincoln LS and showed it to me today. Sounds decently good for being in some cookie cutter wholesale house box on some piece of sh** amp (a sounds storm i think?) anyway I will mic it tomorrow and see what it does.
its a tc9 motor iirc:)
Yep //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I got 3 TC9 drivers and them look the same as mine //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
oem are 190oz , they do look very similar
10" revo
3.5" vc
one 10"spider
Qts 0.38
Re 4.6 Ω
Fs 28 Hz
Cms 118 µM/N
Vas 17.4 lit
Mms 270 g
BL 23.0 Tm
Sd 0.032 m²
SPL 81.7 dB
Specifications
Voice Coil Configuration D2 Ω
Mounting Depth 7.35″
Driver Cutout Diameter 9.25″
Overall Driver Diameter 10.52″
Magnet Weight 195 oz
Driver Weight 32 lbs
MSRP $449
Performance 10″
BL²/Re 115 N²/W
Xmax 28 mm
TLS:
Recommended Amplification 1500 W RMS
4th order reflex enclosure volume 0.8 - 1.5 ft³
2nd order sealed enclosure volume 0.5 - 1.5 ft³
10" oem
Features:
- Lightweight Honeycomb glass fiber cone
- 1" tall NBR surround
- 28mm xmax
- 190 ounce motor
- 800 watts RMS
- 3" wide, long-wind AL voice coil
- Dual 8.5" spiders with woven leads
- Single 4 ohm DCR or Dual 4 ohm DCR
- Actual weight: 29.5 pounds
- Price $175 shipped
Specs:
- Qts 0.357
- Qes 0.400
- Qms 3.35
- Fs 30Hz
- Res 3.11 ohms
- Ls 4.0 mH
- Lp 6.26 mH
- Rp 9.9 ohms
- Dia 208mm
- Vas 19.3 liters
- Mms 224 grams
- Cms 119 um/N
- BL 18.35Tm
- Spl 83.3dB
Enclosure Recoomendations:
- Small Sealed: 0.3 cubic feet
- Large Sealed 0.6 cubic feet
- Ported: 0.5-0.6 cubic feet with a single 10" or 12" PR
You're just poor //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
yes i am, and almost 500bux for a "beefy" TC9 is still ridiculous IMHO. But if it works for u then i have no problems with that //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Parker G
Parker G
Bloomington,Il
photocrazy8
