Audiopipe AQX-3500.1 BänkTest
Hi
A test on constant ohm not with woffer
A test in 5 % thd on oslioskop
start volt 14.4 end drop to 12.5 singel amp 11.5 straped
start volt 17.7 end drop to 14.7 singel amp 13.3 straped
if you think this is lie is up to you is was 5 more end me when a test this amp ..
HiA test on constant ohm not with woffer
Thanks for undertaking the time to do these tests.
Do you have a figure at somewhere around or less than 1%THD?
you listed ur tests wrong 14.7 volts is after voltage drop.
you need to RMS clamp with a woofer playing a test tone.
the RD amps have been recalled the ap's dont have any problems...
All I can say is HUH to this thread.
How did you test them. Did you use a true RMS meter. To measure amps, voltage. What was your IMP rise to. What did your eletrical consist of.
Hello To my post. X2 to it too. Didnt even use a sub for it either.
Do some research on how to do these tests then come back to us.
R4-junior
R4-junior
sweden
ninjawhiteboy12
